9.4 -
I’m trying to setup Prometheus metrics from my ECS containers that are in CloudWatch on Grafana board -
- I set up an ECS microservice with a Java agent to collect JMX metrics accessible through port 9404
- I set up an ECS Prometheus “collector” service to scrape the metrics on port 9404 and send them to CloudWatch
- I see the following in CloudWatch
"CloudWatchMetrics": [
"Metrics": [
"Name": "jvm_memory_pool_bytes_used"
"Dimensions": [
"ClusterName",
"TaskDefinitionFamily",
"pool"
"Namespace": "ECS/ContainerInsights/Prometheus"
"ClusterName": "feature",
"ECS_PROMETHEUS_EXPORTER_PORT": "9404",
"Java_EMF_Metrics": "true",
"LaunchType": "FARGATE",
"StartedBy": "ecs-svc/3763850937600431306",
"TaskDefinitionFamily": "my-service-feature",
"TaskGroup": "service:my-service",
"TaskRevision": "25",
"Timestamp": "1708563763792",
"Version": "0",
"container_name": "my-service-feature",
"instance": "10.23.x.x:9404",
"job": "cwagent-ecs-file-sd-config",
"jvm_memory_pool_bytes_committed": 85983232,
"jvm_memory_pool_bytes_init": 0,
"jvm_memory_pool_bytes_max": -1,
"jvm_memory_pool_bytes_used": 82473672,
"pool": "Metaspace",
"prom_metric_type": "gauge"
- I set up an AWS Grafana workspace, and choosing CloudWatch us-east-1 as a data source
- When I try to setup a Dashboard, I don’t see the “ECS/ContainerInsights/Prometheus” namespace in the “Namespace” dropdown list.
What happened?
When I try to setup a Dashboard, I don’t see the “ECS/ContainerInsights/Prometheus” namespace in the “Namespace” dropdown list. -
I expect to see the “ECS/ContainerInsights/Prometheus” in the Namespace dropdown list. See attached.
I don’t think I have config issues. -
No. -
I started here Grafana dashboards overview | Grafana documentation
