Using Grafana 11.3.1 and Prometheus v2.55.0 with Docker on a Ubuntu Azure VM
Hello all & Happy New Year,
I’m currently trying to monitor a custom Connector inside a confluentinc/cp-server-connect:7.6.0 . I’m trying to get some JMX metrics from that connector that go beyond the standard metrics of these kafka connectors.
‘Full’ config is at the bottom.
I already added the jmx prometheus agent to the confluentinc/cp-server-connect:7.6.0 with
KAFKA_JMX_OPTS: -javaagent:/usr/share/jmx_exporter/jmx_prometheus_javaagent-0.20.0.jar=9998:/usr/share/jmx_exporter/kafka-connect.yml
I also set the KAFKA_JMX_PORT: 9999 and KAFKA_JMX_HOSTNAME: 127.0.0.1 env variables for the connect.
I adjusted the kafka-connect.yml to include the custom metrics and also everything as a fallback like so:
lowercaseOutputName: true
rules:
# Custom pattern for specific metrics
- pattern: '^org\\.init\\.ohja\\.kafka\\.connect:connector=(?<connector>[^,]+),task=(?<task>[^,]+),type=(?<type>[^,]+),attribute=(?<attribute>.*)'
labels:
connector: '$connector'
task: '$task'
type: '$type'
attrNameSnakeCase: true
type: GAUGE
help: 'Ohja custom metric for attribute: ${attribute}'
# Fallback rule for all other metrics
- pattern: '.*'
type: GAUGE
When looking in prometheus however I can see every jmx metric besides my custom ones from the connector.
So I ssh into my VM and try to find the metrics with JMXTerm and lo and behold there they are with the following steps:
java -jar jmxterm-1.0-alpha-4-uber.jar
Welcome to JMX terminal. Type "help" for available commands.
$>open 127.0.0.1:9999
#Connection to 127.0.0.1:9999 is opened
$>info -b org.init.ohja.kafka.connect:connector=Connector_David,task=0,type=odatav2-source-task-metrics
#mbean = org.init.ohja.kafka.connect:connector=Connector_David,task=0,type=odatav2-source-task-metrics
#class name = org.apache.kafka.common.metrics.JmxReporter$KafkaMbean
# attributes
%0 - 0-entityset (double, r)
%1 - 0-position (double, r)
%2 - 0-service (double, r)
%3 - 0-service-url (double, r)
%4 - 0-topic (double, r)
%5 - 0-uri-type (double, r)
%6 - active-subscriptions (double, r)
%7 - last-extraction (double, r)
%8 - retries (double, r)
#there's no operations
#there's no notifications
Going to IP_OF_MY_VM:9998 I can see:
# HELP org_init_ohja_kafka_connect_kafka_metrics_count_count total number of registered metrics org.init.ohja.kafka.connect:name=null,type=kafka-metrics-count,attribute=count
# TYPE org_init_ohja_kafka_connect_kafka_metrics_count_count untyped
org_init_ohja_kafka_connect_kafka_metrics_count_count 10.0
but no other metrics.
The full domain in jmxterm would be:
#domain is set to org.init.ohja.kafka.connect
$>beans
#domain = org.init.ohja.kafka.connect:
org.init.ohja.kafka.connect:connector=OData2SourceConnectorConnector_David,task=0,type=odatav2-source-task-metrics
org.init.ohja.kafka.connect:type=kafka-metrics-count
$>info -b org.init.ohja.kafka.connect:connector=OData2SourceConnectorConnector_David,task=0,type=odatav2-source-task-metrics
#mbean = org.init.ohja.kafka.connect:connector=OData2SourceConnectorConnector_David,task=0,type=odatav2-source-task-metrics
# attributes
But only the metrics count actually shows up in prometheus.
My full configuration is as follows:
Prometheus & Grafana in my docker-compose.yml
prometheus:
image: prom/prometheus:v2.55.0
ports:
- "9090:9090"
volumes:
- ./prometheus.yml:/etc/prometheus/prometheus.yml
command:
- '--config.file=/etc/prometheus/prometheus.yml'
depends_on:
- connect
grafana:
image: grafana/grafana:11.3.1
ports:
- "3000:3000"
volumes:
- "/home/Admin/monitoring/grafana-data:/var/lib/grafana"
- "/home/Admin/monitoring/grafana/provisioning:/etc/grafana/provisioning"
Connect in my docker-compose.yml:
connect:
image: confluentinc/cp-server-connect:7.6.0
hostname: connect
container_name: connect
volumes:
- "/home/Admin/docker-volume/docker-volume-confluent:/usr/share/confluent-hub-components"
- "/home/Admin/monitoring:/usr/share/jmx_exporter/"
- "/home/Admin/docker-volume/docker-volume-schemas:/app/schemas"
- /home/Admin/monitoring/kafka-logs:/var/log/kafka-connect
depends_on:
- broker
- controller
- schema-registry
ports:
- "8083:8083"
- "9999:9999" # JMX port
- "9998:9998" #Testing
environment:
CONNECT_BOOTSTRAP_SERVERS: 'broker:29092'
CONNECT_REST_ADVERTISED_HOST_NAME: connect
CONNECT_GROUP_ID: compose-connect-group
CONNECT_CONFIG_STORAGE_TOPIC: docker-connect-configs
CONNECT_CONFIG_STORAGE_REPLICATION_FACTOR: 1
CONNECT_OFFSET_FLUSH_INTERVAL_MS: 10000
CONNECT_OFFSET_STORAGE_TOPIC: docker-connect-offsets
CONNECT_OFFSET_STORAGE_REPLICATION_FACTOR: 1
CONNECT_STATUS_STORAGE_TOPIC: docker-connect-status
CONNECT_STATUS_STORAGE_REPLICATION_FACTOR: 1
CONNECT_KEY_CONVERTER: org.apache.kafka.connect.storage.StringConverter
CONNECT_VALUE_CONVERTER: io.confluent.connect.avro.AvroConverter
CONNECT_VALUE_CONVERTER_SCHEMA_REGISTRY_URL: http://schema-registry:8081
# CLASSPATH required due to CC-2422
CLASSPATH: /usr/share/java/monitoring-interceptors/monitoring-interceptors-7.6.0.jar
CONNECT_PRODUCER_INTERCEPTOR_CLASSES: "io.confluent.monitoring.clients.interceptor.MonitoringProducerInterceptor"
CONNECT_CONSUMER_INTERCEPTOR_CLASSES: "io.confluent.monitoring.clients.interceptor.MonitoringConsumerInterceptor"
CONNECT_PLUGIN_PATH: "/usr/share/java,/usr/share/confluent-hub-components"
CONNECT_LOG4J_LOGGERS: org.I0Itec.zkclient=ERROR,org.reflections=ERROR,com.sap.conn.jco=ERROR,org.init.ohja.kafka.connect=DEBUG
#Specify a Log4j properties file at Kafka startup
KAFKA_LOG4J_OPTS: "-Dlog4j.configuration=file:/usr/share/confluent-hub-components/connect-log4j.properties"
_JAVA_OPTIONS: -Xmx6g -Xms6g -XX:MaxPermSize=1024m
CONNECT_EXACTLY_ONCE_SOURCE_SUPPORT: enabled
KAFKA_OPTS: "-Dcom.sun.management.jmxremote=true \
-Dcom.sun.management.jmxremote.authenticate=false \
-Dcom.sun.management.jmxremote.ssl=false \
-Djava.rmi.server.hostname=127.0.0.1 \
-Dcom.sun.management.jmxremote.port=9999 \
-Dcom.sun.management.jmxremote.rmi.port=9999"
prometheus.yml:
global:
scrape_interval: 10s
scrape_timeout: 10s
evaluation_interval: 10s
rule_files: ["rules/*.yml"]
scrape_configs:
- job_name: kafka
scrape_timeout: 10s
scheme: http
static_configs:
- targets: ["broker:9200"]
- job_name: kafka-connect
scrape_timeout: 10s
metrics_path: /metrics
scheme: http
static_configs:
- targets: ["connect:9998"]
- job_name: connect
scrape_timeout: 10s
scheme: http
static_configs:
- targets: ["connect:9999"]
- job_name: ksql
scrape_timeout: 10s
scheme: http
static_configs:
- targets: ["ksqldb-server:7010"]
kafka-connect.yml:
rules:
- pattern: '^org\\.init\\.ohja\\.kafka\\.connect:connector=(?<connector>[^,]+),task=(?<task>[^,]+),type=(?<type>[^,]+)'
# Tells jmx_exporter to create separate metrics for each attribute name.
# 'attrNameSnakeCase: true' converts `last-extraction` -> `last_extraction`.
# Name for each metric; the placeholder ${attr} becomes the attribute name.
labels:
connector: "$connector"
task: "$task"
type: "$type"
# Typically a gauge is fine for these custom attributes
type: GAUGE
help: "Ohja custom metric: ${attr}"
- pattern: ".*"
type: GAUGE
In Prometheus the status for kafka-connect is UP, while the status for connect is DOWN. Going to IP_OF_MY_VM:9998 shows me the metrics etc, going to IP_OF_MY_VM:9999 shows ERR_EMPTY_RESPONSE
I hope someone can help me with this as I am struggling to get these other metrics into Prometheus.
Best regards, Looking forward to a great year 2025
David
