v8.5.3 on ECS FARGATE
- What are you trying to achieve?
Setup a Cloudwatch datasource base on IAM instance role
- What happened?
Grafana only looks for IAM credentials in EC2 metadata endpoint (http://169.254.169.254/latest/meta-data/iam/security-credentials/) and does not try on ECS FARGATE metadata endpoint ( $ECS_CONTAINER_METADATA_URI or $ECS_CONTAINER_METADATA_URI_V4 from env vars).
Grafana to try both EC2 instance metadata AND ECS FARGATE metadata.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
CloudWatch metrics query failed: EC2RoleRequestError: no EC2 instance role found caused by: RequestError: send request failed caused by: Get “http://169.254.169.254/latest/meta-data/iam/security-credentials/”: dial tcp 169.254.169.254:80: connect: invalid argument 2. CloudWatch logs query failed: EC2RoleRequestError: no EC2 instance role found caused by: RequestError: send request failed caused by: Get “http : // 169.254.169.254/latest/meta-data/iam/security-credentials/”: dial tcp 169.254.169.254:80: connect: invalid argument
Is there a way to specify the Instance metadata url ?
