Cannot color table of elasticsearch datasource with grafana 7.1.5
I am using grafana(version:7.1.5) to draw a table panel of elasticsearch datasource. I have set Thresholds and chosed Cell display mode. However, the corresponding columns of the table panel are grey instead of the color I have set in thresholds, just as the fourth screenshot. Why?
Hi @lwlei - trying to verify if this is a bug with the ES data source and thresholds or not. There was a user who reported a similar issue on GitHub. Can you add this info there so the team can get additional information? https://github.com/grafana/grafana/issues/26726
