Can we create a custom variable using multiple cusom variables
I have some custom variables like CPU usage, Memory Usage, CPU cores, and Total Memory.
Now I want to create another custom variable with values 3,5,10. But for every value in the new custom variable, I want to pass values using in above custom variables.
Will it be possible? If so, could you please help?
Thanks in advance.
Thanks & regards,
Bharath Kumar.
Hello
Is this different than this post?
Hello @yosiasz,
Yes. It is different from that. In my previous post, I am asking whether I can assign any Null value while declaring a custom variable.
Here I am asking that for every key I want to add 4 conditions from 4 previously defined custom variables.
Thanks & regards,
Bharath Kumar.
