Create custom dynamic variable for Prometheus
Hello All,
I want to create a custom variable with key-value pairs.
But I want to value to be changed dynamically… will it be possible?
Actually, I want to pass the current epoch as a value that should increment automatically. will it be possible?
ex: value : ${__from:date:seconds} ----> this will give current epoch time,
can we do any subtraction operations from ${__from:date:seconds}
is my syntax correct?
Can anyone help me?
Thanks & regards,
Bharath Kumar
Hi @chembakayalabharath
What datasource you are using ?
Hello @usman.ahmad ,
Prometheus Data source
This is throwing me syntax error… can anyone help me?
So your query ${__from:date:seconds} does not give me an error when using it.
OR do you get an error when using it with a subtraction operation of yours?
Can you please maybe share some screenshots?
