can not connect to external data source
error : Query failed. Please inspect Grafana server log for details
Which version of Grafana are you using?
Which external data source are you trying to connect to?
What connection parameters have you set up for this data source?
What does the Grafana server log tell you about the failure to connect?
Can you make a manual connection from the Grafana server to the data
source? -
Any other information which might be useful for us to understand your
setup?
Antony.
Version 6.4.3 -
My SQL -
Host : IP:port
Database : my database name
User : my database username
Password : my database password -
Query failed. Please inspect Grafana server log for details -
source? -
setup
- What connection parameters have you set up for this data source?
Host : IP:port
- Can you make a manual connection from the Grafana server to that data
source?
(Telnet 3306 if you don’t have the MySQL client installed)
- What does the Grafana server log tell you about the failure to connect?
You mean the Grafana server log tells you to look at the Grafana server log
for more details?
Which log file are you looking at to see this?
Antony.
My question, how to connect external data source with MySQL.
Hello ! I’m in the same situation. Did you get a solution ?
Thx
Daisy.
Welcome @daisychain
Has the grafana user been given proper permissions on the mysql server?
