Can not connect Grafana to InfluxDB
    Grafana cloud version (V3)
    Using SQL connection trying to connect and visualise data from a Cloud instance of InfluxDB, which is linking to an ESP32 measuring temperature and humidity
  • What happened?
    I follow the Grafana/influxDB documentation, When I go to test and connect I get the following error:
There was an error when testing this data source, please check PDC agent logs.
ERROR: flightsql: rpc error: code = Unauthenticated desc = unauthenticated
Hi @tomgooderham and welcome to the Grafana forum.
Here are my Grafana Cloud settings to use InfluxDB Cloud SQL (or v3 or whatever they are calling it now):
HI Thanks,
Looks like its similar to mine (aside from mine is European based), therefore any further ideas as to what is wrong? Is it something daft like using Browser type? I am using Chrome
Is your bucket name indeed RH1?
Ahhhh - Bingo! Now working!!
