Can Loki be used to perform data aggregation from a log file?
I’m running the latest version of Grafana Docker image; the host machine is running Windows 11.
I have a Grafana-Loki-Promtail setup that is monitoring a log file. The log file documents the number of files being processed by an application over a period of time. Over the course of a day there could be a hundred data points, e.g., “at 6:00am: 17 files downloaded, 6:01am: 80 files downloaded…”.
I would like to change that so instead of seeing the number of files downloaded at every data point, Loki will consolidate the data hourly, e.g., at 6:00-7:00am, 200 files downloaded, 7:00-8:00am, 600 files downloaded…".
I don’t know, that’s why I’m creating this topic. I couldn’t figure it out from the Loki documentation.
  • What happened?
Nothing happened, and that’s the problem.
See above
There’s no configuration because I don’t know where to begin
No
No
I would do the aggregation afterwards.
First create a table with Loki (timestamp, value) and aggregate it as a second step.
That’s how I would do it.
Jo
Hi, thank you for answering!
I already managed to get the basic setup running (Promtail reads the logs, sends it to Loki, which sends it to Grafana to be rendered into a graph). Now I just need guidance to do the second step (aggregating the data).
Any suggestions you can give about this would be greatly appreciated.
What does your tabular data look like? Do you have an example?
In the example above, I want to combine all the data so that the X-axis would be something like 04:00 and the Y-axis will be the sum of file_size_total in all data points from 04:00 - 04:59.
