Grafana version 9.1.0 -
I would like to use the remote_write option, or some other way to do it, so that I can set up a prometheus source that is running locally at my house, on a grafana instance that is running on my free oracle cloud server, so that I can view the grafana dashboard from anywhere without having to port foward. -
I got everything working on grafana cloud, but I would like to self host grafana instead so I don’t have to deal with the 14 day retention. I could not find any information on how to do this, except for port fowarding the port that prometheus uses, which I cannot do. -
What happened?
I could not find anything online about how to do this. -
No. -
If you can put your local Prometheus behind a public DNS, you can remote write data from Oracle Prometheus to Local Prometheus.
That “remote_write” is Mimir (“better Prometheus”) = deploy&configure Mimir on your server - Grafana Mimir | Grafana Labs
Thank you! so if I understand, I just install mimir on to oracle and then I can use remote_write?
