Noobs here, be kind!
I need to change the font size in a Text Panel that I am using for my header on a Dashboard.
Is this possible?
If so, please help?
Is this possible?
If so, please help?
Hi @crayber,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community ![]()
If you mean to increase the text size in the “Text Panel” title, then it is not possible.
But if you want to increase the size inside the content body of a “Text Panel”, then it is possible as it uses the Markdown language.
You can check this GitHub Markdown Formatting Syntax link as reference.
I hope this helps.
