Can do I display Azure Deployment Center log history in Grafana
We have a set of Grafana dashboards which are connected to our Azure system and we have some useful data showing on these dashboards.
However there is 1 selection of data that is eluding me at present, this is Deployment Center logs. In Azure these are visible thus:
So my question is how/can do I display this on a Grafana dashboard, any ideas please?
Thanks in advance for any help on this.
welcome @kevsbox
you are showing a lot of data points, which section of data do you specifically want to visualize?
Is this data accessible via a rest api?
Hi there
What we are hoping to show in a table is Date/Time, Build number and Release Number
Regards
Kev
:point_up_2:
what means are there to access this data.
Good question, I will get back to you
