is it possible to use disabled queries in Grafana graph panels to create Grafana alerts?
Why do you want to do that (Background)?
I am having one metric providing information about disk pace usage on certain directories on a server. This metric I am using to show the information on graph panel.
There is a second metric which is providing also information about disk space usage on certain directories on a server, but is showing the disk space usage in percentage instead of units.
I would like to use the second metric to create Grafana alerts - on the same graph panel (For example: If the disk space usage of a certain directory is going above X%, then ALERT.
Since I do not want to display the scond metric on a Graph panel, I am using Grafanas feature to disable this query.
Now the question is, can I use this disabled query to create Grafana alerts?
Many thanks in advance.
[Grafana version: 6.5, Datasource: Prometheus]
Best regards
HamidJa
