Can datalinks from table panels have conditional logic?
assume i created a table panel via FLUX.
column 1 contains content that i want to access via data-link url: http://normaldest${__value.text}…
but since i also inserted a row for “Total” is it possible to have the hyperlink when ${__value.text} = “Total” resolve to http://otherdest…
you can set data-links on a per-field basis by using the override feature in the panel editor. What version of grafana are you running?
Hello, I am in version 11.2 and I would like to also perform conditional data link depending on the value of a regex of ${__value.text}
