Calling JSON API with Query does not display any data
I have a problem with the data display. I’m displaying queries from our system that uses GraphQL via the JSON API in Postman via a query that I modify to call the JSON API and everything works great. I wanted to port this solution to Grafana, but I am unable to call this data.
My connection is identical, I have Authorization with Bearer token in the header. But the problem still persists on any arrival. Table shows no data. I write the query in body - JSON. Can anyone help me with this? I am a bit frustrated with this.
Thanks!
Welcome @mikolas
Please post result of your graphql json data? also
  • version of grafana
  • visualization you want to use: bar chart, stats, time series?
I use the latest version of Grafana in the Cloud. I don’t know how to find out its version. I don’t know what output you’re interested in, but there isn’t one. No data is being displayed.
I tried to view the data in “Explore data”
There is data returned from postman
But if there is no data in postman porting over to grafana…won’t work either
As I wrote, in postman I enter for example this command:
  "query": "query GetDefaultProducts { products { items { id name ean code quantities { depot { id name } quantityStock quantityReservation quantityAvailable } } } }"
I receive this data:
“data”: {
“products”: {
“items”: [
“id”: 112233,
“name”: “Items123”,
“ean”: “1953211110002”,
“code”: “code”: “items_112233”,
“amount”: [ “quantity”.
“depot”: {
“id”: 111,
“name”: “Stock123”
“quantityStock”: 245,
“quantityReservation”: 4,
“quantityAvailable”: 241
But I’m not getting any data back in Grafana.
Do you see any errors in the browser console? Or are there any errors on the dashboard itself. please send screen shot.
