docker.io/grafana/grafana:10.4.0 on k3s -
I am trying to calculate the 0.95 quantile for a bits per second gauge on prometheus per interface. The problem is that due to the many AS that exist, we only save the top 1000 flows. This results in flows beneath a specific threshold in not having datapoints at all times. There are only datapoints when there is actually traffic. -
I am attempting to calculate the 0.95 quantile of bits per second for each interface by using thequantile_over_time
function in Prometheus and summing the results by theinputifindex
label. The query is designed to aggregate the quantiles for each interface over the specified time range. -
What happened?
The calculated .95 quantile is only calculated in respect to the given datapoints, the time in which no datapoints are recorded (in which the bandwidth is zero) is ignored, resulting in a false value. -
I expected the missing datapoints to be filled with zero values, resulting in a correct calculation of the quantile. -
sum by (inputifindex) (
quantile_over_time(sflow_asn_bps{direction="ingress", src="AS20940 Akamai International B.V."})[$__range}}
No errors. -
I tried adding a vector(0) and multiplying with (1-absent), but to no avail.
monitoring - How to merge zero values (vector(0) with metric values in PromQL - Stack Overflow
https ://community .grafana.com/t/fill-no-data-with-0-for-calculations/58060/6
The problem with that is that a new timeseries with 0s is produced, but it is not combined with the existing, multiple, timeseries. If I sum them not only each timeseries will be merged with the 0 timeseries, but all will be merged, resulting in a completely wrong timeseries.
Thank you for your assistance!
