Button in Canvas: how to use Grafana authorization in requests to Node-RED?
I am using Canvas plugin with several buttons to send HTTP POST requests to Node-RED, as described in this topic.
What is the most proper / easiest way to protect these requests with Grafana authorization? I.e. so as Node-RED accepted these requests only when user is authorized in Grafana?
Grafana version is 10.2
Manual states:
Button elements support triggering basic, unauthenticated API calls
Anyway, may be somebody can share best practices on making such API calls more secure…
what type of auth are you using? out of the box or custom?
out of the box
out of the box is basic uname and upass so would avoid that but instead I would implement bearer token if NR allows that
@grant2 is the man for that
https://nodered.org/docs/api/admin/methods/post/auth/token/
Thank you, will look through @grant2 's posts
