Business table : data links
Hello everyone !
I’m currently using the pluging “Business Table” by Volko Labs and I’m facing an issue regarding the data links.
I would like to show the link for a row while using “Override” but i cannot achieve this and end up showing it for a column.
As you can see on the image, the column “centrale” has the link but i would like to give a different link for every different “centrale”.
Can someone offer their help please, this would be gladly appreciated.
you could use
What exactly should be at the “LeaneM.io” place ?
This may be basic, I’m acually new to parameters in data links, usually I only use a simple link.
Thank you for your help anyway !
only you will know what to put there. a link to a site or a link to a dashboard
