Using Grafana v5.1.4 (a5fe24fcc) and a Postgres data source:
This query works:
SELECT
EXTRACT(EPOCH FROM date_trunc('week', to_timestamp((json->'fields'->>'dateCreated')::int) AT TIME ZONE 'UTC')::date) AS time,
1 as value
FROM
phab_engineering_tasks
WHERE
(json->'fields'->>'dateCreated')::int >= $__unixEpochFrom() AND (json->'fields'->>'dateCreated')::int <= $__unixEpochTo()
GROUP BY
time
However this one doesn’t work (“Unknown macro __timeSec” error):
SELECT
$__timeSec(date_trunc('week', to_timestamp((json->'fields'->>'dateCreated')::int) AT TIME ZONE 'UTC')::date),
1 as value
FROM
WHERE
GROUP BY
time
And this one doesn’t either (“pq: syntax error at or near “GROUP””):
SELECT
1 as value
FROM
WHERE
$__unixEpochFilter((json->'fields'->>'dateCreated')::int)
GROUP BY
time
There is no macro named $__timeSec you probably meant $__timeEpoch. At the moment grafana does not allow arbitrarily complex expression as macro arguments. Macro arguments must not contain , as that is used as separator for macro arguments.
Can you show the expanded query for your 3rd example. There is a button called ‘Generated SQL’ in the query editor that shows the expanded query.
From http://docs.grafana.org/features/datasources/postgres/:slight_smile:
$__timeSec(dateColumn) Will be replaced by an expression to rename the column to time and converting the value to unix timestamp. For example, extract(epoch from dateColumn) as time
xhrStatus:"complete"
request:Object
method:"POST"
url:"api/tsdb/query"
data:Object
to:"1530543648092"
queries:Array[1]
0:Object
refId:"A"
intervalMs:600000
maxDataPoints:815
datasourceId:3
rawSql:"SELECT EXTRACT(EPOCH FROM date_trunc('week', to_timestamp((json->'fields'->>'dateCreated')::int) AT TIME ZONE 'UTC')::date) AS time, 1 as value FROM phab_engineering_tasks WHERE $__unixEpochFilter((json->'fields'->>'dateCreated')::int) GROUP BY time"
format:"table"
response:Object
results:Object
A:Object
error:"pq: syntax error at or near "GROUP""
refId:"A"
meta:Object
sql:"SELECT EXTRACT(EPOCH FROM date_trunc('week', to_timestamp((json->'fields'->>'dateCreated')::int) AT TIME ZONE 'UTC')::date) AS time, 1 as value FROM phab_engineering_tasks WHERE (json->'fields'->>'dateCreated' >= 1529938848 AND (json->'fields'->>'dateCreated' <= 1530543648::int) GROUP BY time"
series:null
tables:null
message:"pq: syntax error at or near "GROUP""
Looks like the parens are not properly closed in the generated sql. The following query should work though:
SELECT
1 as value
FROM
WHERE
(json->'fields'->>'dateCreated')::int BETWEEN $__unixEpochFrom() AND $__unixEpochTo()
GROUP BY
time
