Build hangs at 'yarn run plugins:build-bundled' with 'make clean all'
My build does not proceed after ‘yarn run plugins:build-bundled’ step and hangs forever. This was working before, it stopped working after 8.5.0. OTOH 8.4.7 builds successfully as expected.
    Grafana: 8.5.2
    Fedora 35
    Nodejs: 16.14.0
    Trying to build grafana for my own deployment with ‘make clean all’
    Trying to get a built grafana for deployment to our production systems
  • What happened?
    Build does not proceed after ‘yarn run plugins:build-bundled’ step
    It builds as expected
webpack 5.70.0 compiled with 2 warnings in 195861 ms
Running in local/linked mode
Running Bundle managed plugins task
  [internal]: input-datasource building...
  [Error: ENOENT: no such file or directory, scandir '/code/grafana/gopath/grafana/plugins-bundled/external'] {
    errno: -2,
    code: 'ENOENT',
    syscall: 'scandir',
    path: '/code/grafana/gopath/grafana/plugins-bundled/external'
