lgt
August 5, 2021, 1:34am
#1
When I start the node by docker ,it show msg like this. What’s the problem here, or how can I find the detail error somewhere? thanks
Hi @lgt
This appears to be a networking issue on your side, relating to memberlist
Here is an issue which appears related to your question, with some debugging instructions:
opened 09:36AM - 07 Jan 19 UTC
closed 10:53PM - 15 Jan 19 UTC
I'm trying to find out what caused this problem, but i'm failed.
the logs
2019/01/07 17:25:30 [DEBUG] memberlist: Failed ping: hkam30008 (timeout reached)
2019/01/07 17:25:31 [DEBUG] memberlist: Stream connection from=100.69.28.7:63057
2019/01/07 17:25:31 [DEBUG] memberlist: Failed ping: hkam30162 (timeout reached)
2019/01/07 17:25:32 [WARN] memberlist: Was able to connect to hkam30162 but other probes failed, network may be misconfigured
2019/01/07 17:25:32 [DEBUG] memberlist: Failed ping: hkam30009 (timeout reached)
2019/01/07 17:25:32 [DEBUG] agent: Node info in sync
2019/01/07 17:25:33 [WARN] memberlist: Was able to connect to hkam30009 but other probes failed, network may be misconfigured
2019/01/07 17:25:33 [DEBUG] memberlist: Stream connection from=100.69.28.1:42918
2019/01/07 17:25:33 [DEBUG] memberlist: Stream connection from=100.69.28.8:63323
2019/01/07 17:25:34 [DEBUG] memberlist: Stream connection from=100.69.28.16:47760
2019/01/07 17:25:37 [DEBUG] memberlist: Failed ping: hkam30059 (timeout reached)
2019/01/07 17:25:39 [DEBUG] memberlist: Stream connection from=100.69.31.156:24380
2019/01/07 17:25:39 [DEBUG] memberlist: Failed ping: hkam30020 (timeout reached)
2019/01/07 17:25:40 [WARN] memberlist: Was able to connect to hkam30020 but other probes failed, network may be misconfigured
2019/01/07 17:25:41 [DEBUG] memberlist: Failed ping: hkam30163 (timeout reached)
2019/01/07 17:25:42 [WARN] memberlist: Was able to connect to hkam30163 but other probes failed, network may be misconfigured
the **consul info**
agent:
check_monitors = 0
check_ttls = 0
checks = 0
services = 0
build:
prerelease =
revision = 75ca2ca
version = 0.9.2
consul:
bootstrap = false
known_datacenters = 4
leader = false
leader_addr = 100.69.88.1:8300
server = true
raft:
applied_index = 6271351
commit_index = 6271351
fsm_pending = 0
last_contact = 6.756206ms
last_log_index = 6271351
last_log_term = 16
last_snapshot_index = 6265248
last_snapshot_term = 14
latest_configuration = [{Suffrage:Voter ID:100.69.24.1:8300 Address:100.69.24.1:8300} {Suffrage:Voter ID:100.69.24.2:8300 Address:100.69.24.2:8300} {Suffrage:Voter ID:100.69.24.3:8300 Address:100.69.24.3:8300} {Suffrage:Voter ID:100.69.88.2:8300 Address:100.69.88.2:8300} {Suffrage:Voter ID:100.69.88.1:8300 Address:100.69.88.1:8300} {Suffrage:Voter ID:100.69.88.3:8300 Address:100.69.88.3:8300}]
latest_configuration_index = 5935917
num_peers = 5
protocol_version = 2
protocol_version_max = 3
protocol_version_min = 0
snapshot_version_max = 1
snapshot_version_min = 0
state = Follower
term = 16
runtime:
arch = amd64
cpu_count = 40
goroutines = 141
max_procs = 40
os = linux
version = go1.8.3
serf_lan:
coordinate_resets = 0
encrypted = false
event_queue = 0
event_time = 6
failed = 0
health_score = 0
intent_queue = 0
left = 0
member_time = 1208
members = 41
query_queue = 0
query_time = 1
serf_wan:
encrypted = false
event_queue = 0
event_time = 1
failed = 0
health_score = 0
intent_queue = 0
left = 0
member_time = 45
members = 18
query_queue = 0
query_time = 1
the **members**
Node Address Status Type Build Protocol DC
hkam30005 100.69.28.1:8301 alive client 0.9.2 2 hk1
hkam30006 100.69.28.2:8301 alive client 0.9.2 2 hk1
hkam30007 100.69.28.3:8301 alive client 0.9.2 2 hk1
hkam30008 100.69.28.4:8301 alive client 0.9.2 2 hk1
hkam30009 100.69.28.5:8301 alive client 0.9.2 2 hk1
hkam30010 100.69.28.6:8301 alive client 0.9.2 2 hk1
hkam30011 100.69.28.7:8301 alive client 0.9.2 2 hk1
hkam30012 100.69.28.8:8301 alive client 0.9.2 2 hk1
hkam30013 100.69.24.1:8301 alive server 0.9.2 2 hk1
hkam30014 100.69.24.2:8301 alive server 0.9.2 2 hk1
hkam30015 100.69.24.3:8301 alive server 0.9.2 2 hk1
hkam30019 100.69.28.12:8301 alive client 0.9.2 2 hk1
hkam30020 100.69.28.13:8301 alive client 0.9.2 2 hk1
hkam30021 100.69.28.14:8301 alive client 0.9.2 2 hk1
hkam30022 100.69.28.15:8301 alive client 0.9.2 2 hk1
hkam30023 100.69.28.16:8301 alive client 0.9.2 2 hk1
hkam30058 100.69.31.150:8301 alive client 0.9.2 2 hk1
hkam30059 100.69.31.151:8301 alive client 0.9.2 2 hk1
hkam30162 100.69.31.156:8301 alive client 0.9.2 2 hk1
hkam30163 100.69.31.157:8301 alive client 0.9.2 2 hk1
hkbm30029 100.69.88.1:8301 alive server 0.9.2 2 hk1
hkbm30030 100.69.88.2:8301 alive server 0.9.2 2 hk1
hkbm30031 100.69.88.3:8301 alive server 0.9.2 2 hk1
hkbm30034 100.69.92.150:8301 alive client 0.9.2 2 hk1
hkbm30035 100.69.92.151:8301 alive client 0.9.2 2 hk1
hkbm30036 100.69.92.152:8301 alive client 0.9.2 2 hk1
hkbm30037 100.69.92.153:8301 alive client 0.9.2 2 hk1
hkbm30038 100.69.92.154:8301 alive client 0.9.2 2 hk1
hkbm30039 100.69.92.155:8301 alive client 0.9.2 2 hk1
hkbm30040 100.69.92.156:8301 alive client 0.9.2 2 hk1
hkbm30041 100.69.92.157:8301 alive client 0.9.2 2 hk1
hkbm30042 100.69.92.158:8301 alive client 0.9.2 2 hk1
hkbm30043 100.69.92.159:8301 alive client 0.9.2 2 hk1
hkbm30044 100.69.92.160:8301 alive client 0.9.2 2 hk1
hkbm30045 100.69.92.161:8301 alive client 0.9.2 2 hk1
hkbm30046 100.69.92.162:8301 alive client 0.9.2 2 hk1
hkbm30048 100.69.92.163:8301 alive client 0.9.2 2 hk1
hkbm30061 100.69.92.164:8301 alive client 0.9.2 2 hk1
hkbm30062 100.69.92.165:8301 alive client 0.9.2 2 hk1
hkbm30063 100.69.92.166:8301 alive client 0.9.2 2 hk1
hkbm30064 100.69.92.167:8301 alive client 0.9.2 2 hk1
the **client config**
"datacenter": "HK1",
"data_dir": "/pacloud/ccmp/base/ccmp/data",
"log_level": "DEBUG",
"node_name": "hkbm30064",
"server": false,
"client_addr":"0.0.0.0",
"bind_addr":"100.69.92.167",
"retry_join":["100.69.24.1","100.69.24.2","100.69.24.3","100.69.88.1","100.69.88.2","100.69.88.3"]
lgt
August 5, 2021, 8:16am
#3
Thanks for help, I think is not the network problem , because all the firewall is closed ,and I have try to ping from each node and it’s ok. Could you please give me more advice , thanks~
Here is my config.yaml:
and my docker-compose.yaml:
Pings will only tell if your network can pass around ICMP packets; this is unrelated to what your problem is here.
Did you follow the debugging steps provided in that issue?
Are all the required ports accessible, etc?
lgt
August 6, 2021, 12:48am
#5
I have tried telnet 7946 and it’s ok. Is there any more required ports I need to test?
lgt
August 6, 2021, 12:56am
#6
And how can I debug it because loki is running on the server. I’m not familiar with the programing language in that issue show. I guess it’s like a timeout fallback?
