I am trying to deploy three Loki v.2.9.4 instances in monolithic mode on my nomad-cluster, using docker. Each instance is running on a different nomad node. I am facing some issues with the memberlist component, any help is very appreciated.
Once I spin up the Loki instances the log is filled with the following warn message and continues to do so:
level=warn ts=2024-02-09T11:32:27.228361615Z caller=tcp_transport.go:253 component="memberlist TCPTransport" msg="failed to read message type" err=EOF remote=172.17.0.1:40984
level=warn ts=2024-02-09T11:32:29.229249009Z caller=tcp_transport.go:253 component="memberlist TCPTransport" msg="failed to read message type" err=EOF remote=172.17.0.1:49542
level=warn ts=2024-02-09T11:32:31.230123383Z caller=tcp_transport.go:253 component="memberlist TCPTransport" msg="failed to read message type" err=EOF remote=172.17.0.1:49556
level=warn ts=2024-02-09T11:32:33.231003539Z caller=tcp_transport.go:253 component="memberlist TCPTransport" msg="failed to read message type" err=EOF remote=172.17.0.1:49572
level=warn ts=2024-02-09T11:32:35.231360847Z caller=tcp_transport.go:253 component="memberlist TCPTransport" msg="failed to read message type" err=EOF remote=172.17.0.1:49574
level=warn ts=2024-02-09T11:32:37.23184231Z caller=tcp_transport.go:253 component="memberlist TCPTransport" msg="failed to read message type" err=EOF remote=172.17.0.1:49586
Loki is trying to connect to the docker host ip address instead of the address of the container as you can see with 172.17.0.1
The members are active and are discovered through consul and the DNS SRV lookup.
Ring status:
Running configuration
auth_enabled: false
querier:
max_concurrent: 16
query_scheduler:
max_outstanding_requests_per_tenant: 32768
ingester:
chunk_idle_period: 5m
wal:
dir: /loki/ingester-wal
storage_config:
tsdb_shipper:
active_index_directory: /loki/tsdb-index
cache_location: /loki/tsdb-cache
shared_store: s3
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: s3
schema: v12
store: tsdb
compactor:
working_directory: /loki/compactor
retention_enabled: true
limits_config:
enforce_metric_name: false
reject_old_samples: true
retention_period: 4320h
memberlist:
node_name: loki0
join_members:
- _loki._memberlist.service.consul.io
common:
ring:
kvstore:
store: memberlist
instance_addr: 10.41.0.226
storage:
s3:
s3forcepathstyle: true
bucketnames: "loki"
endpoint: https://URL
region: eu-de`
