Hey there,
I’m new in Grafana and his services. My goal is to implement Grafana Tempo. For this case I the use tempo-distrbuted helm chart.
Now I want to test if all works correctly and I got this error:
ts=2021-11-12T09:30:46.444315587Z caller=memberlist_logger.go:74 level=warn msg="Was able to connect to tempo-distributed-ingester-0-19d561c3 but other probes failed, network may be misconfigured" │
│ level=warn ts=2021-11-12T09:30:50.437936818Z caller=tcp_transport.go:418 msg="TCPTransport: WriteTo failed" addr=10.4.0.163:7946 err="dial tcp 10.4.0.163:7946: connect: no route to host"
I don’t why the gossip ring point to this IP addresses because they doesn’t exists in the kubernetes cluster.
