Build a Panel Plugin - Error
Hello Everybody!
I am currently in the process of creating a new panel plugin by following the tutorial located here: Create Plugin and here Build your first plugin.
Steps I followed in accordance with the tutorial:
npm init @grafana/plugin
selected panel type, name, description and so on…
npm i
npm run dev
I got an error by npm run dev:
ERROR in ./module.ts
Module build failed (from ../node_modules/swc-loader/src/index.js):
Error: failed to handle: base_dir(./src) must be absolute. Please ensure that `jsc.baseUrl` is specified correctly.
webpack 5.88.2 compiled with 1 error in 330 ms
Type-checking in progress...
thread '<unnamed>' panicked at 'base_dir(./src) must be absolute. Please ensure that `jsc.baseUrl` is specified correctly.', /usr/local/cargo/registry/src/index.crates.io-6f17d22bba15001f/swc_ecma_transforms_module-0.173.28/src/path.rs:104:13
assets by status 17.1 KiB [cached] 6 assets
./module.ts 39 bytes [built] [1 error]
Can someone provide assistance? I expected it to work smoothly since the instructions are directly from Grafana, and I am following the prescribed steps. Any help would be greatly appreciated!
Cheers,
Marcelo
Hi there @companymvms - this is due to a bug which was introduced in swc/core which was released yesterday. It has since been fixed, we’re just waiting for the new release.
For now, you’ll need to downgrade to the previous version "@swc/core": "1.3.75" in your package.json
related issue: Bug: everything fresh installed, yarn build doesnt work. · Issue #344 · grafana/plugin-tools · GitHub
Thank you very much @davidharris . Which version exactly it is working? I tried 1.3.76 and 1.3.62 … I will try others here… It is a great tipp! :slight_smile:
No problem - 1.3.76 is latest which includes the bug, my post above recommends 1.3.75 which we’ve confirmed still works as expected :slight_smile:
Thank you very much @davidharris . Which version exactly it is working? I tried 1.3.76 and 1.3.62 and got the same error … I tried 1.3.0 and I got only this error now:
Thanks and any advice would be great!
1.3.75
Have you remembered to re-run npm i after changing the version in package.json?
Hi @davidharris , thanks for your support!
Yes, I remember. I’m encountering the same error even with version 1.3.75. Additionally, I deleted the package-lock.json file and re-ran npm i just to be certain.
Afraid I can’t reproduce then :confused: it works fine for me with 1.3.75.
2 options you could try:
  • start afresh in a new directory just in case and ensure package.json looks like this before running npm i
    Screenshot 2023-08-11 at 17.39.30
  • Could try and push your code to a public repo and I can take a look.
Hi @companymvms you need to set "@swc/core": "1.3.75" (notice the removal of the ^ symbol) and run npm install later to see this issue fixed. Or you can do it all in a single command without having to modify any file yourself by running npm install -E @swc/core@1.3.75 (notice -E to install the exact version)
If you keep the ^ it’ll keep installing the latest patch version even if you specify the specific patch version yourself.
For anyone looking to fix this problem:
A new version of create-plugin had been released that has 1.3.75 pinned as a dependency. Update to the latest create-plugin configuration:
npx @grafana/create-plugin@latest update
Note: make sure to select “Yes, all of them” when prompted Would you like to update the following dependencies in the package.json?
Then run npm install to install the correct dependencies.
Thanks @davidharris . I created just a new project from scratch and it worked! Thanks
Thank you @academo! Good advice!!! I have just created a new project from scratch and it is now functioning.
