Just installed Grafana. Seems OK as server is running but when I open webpage all I get is a blank page my URL shows as http://10.0.0.166:3000/login, the IP is the device IP on my network.
Have unistalled and installed a few time but same result. This is a Debian install onto a Raspberry Pi running Raspbian.
Hi, I am seeing the same kind of issue. I am running on a Raspberry pi 3 and fresh install of Debian Stretch.
I used packages installation, and the database seems to be starting OK, but I get no response from community.grafana.com other than the tab show the Grafana logo, so there is a little life there, but no GUI, so I am reaching out to see if I can find some things to try.
I ran into some pre-req issues and had attempted the grafana install (failed due rto pre-reqs), but I located and installed them all and the Grafana-data finally completed without error.
55 wget http ://ftp.us.debian.org/debian/pool/main/g/grafana/grafana-data_2.6.0+dfsg-3_all.deb
74 sudo dpkg -i grafana-data_2.6.0+dfsg-3_all.deb
I ran into the same issue with pre-reqs when installing Grafana…
77 wget http ://ftp.us.debian.org/debian/pool/main/g/grafana/grafana_2.6.0+dfsg-3_armhf.deb
89 sudo dpkg -i grafana_2.6.0+dfsg-3_armhf.deb
Once the pre-reqs were installed the Grafana packages installed OK, but I get a blank page when attempting to look at community.grafana.com.
Here is output of the status command…
pi@reporterpi:/var/log/grafana $ sudo systemctl daemon-reload
pi@reporterpi:/var/log/grafana $ sudo systemctl start grafana-server
pi@reporterpi:/var/log/grafana $ sudo systemctl status grafana-server
● grafana.service - Starts and stops a single grafana instance on this system
Loaded: loaded (/lib/systemd/system/grafana.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2018-01-14 01:47:27 EST; 15h ago
Docs: http://docs.grafana.org
Main PID: 405 (grafana)
CGroup: /system.slice/grafana.service
└─405 /usr/sbin/grafana --config=/etc/grafana/grafana.ini cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/
Jan 14 01:47:29 reporterpi grafana[405]: [0]: default.paths.data=/var/lib/grafana
Jan 14 01:47:29 reporterpi grafana[405]: [1]: default.paths.logs=/var/log/grafana
Jan 14 01:47:29 reporterpi grafana[405]: Paths:
Jan 14 01:47:29 reporterpi grafana[405]: home: /usr/share/grafana
Jan 14 01:47:29 reporterpi grafana[405]: data: /var/lib/grafana
Jan 14 01:47:29 reporterpi grafana[405]: logs: /var/log/grafana
Jan 14 01:47:29 reporterpi grafana[405]: 2018/01/14 01:47:29 [I] Database: sqlite3
Jan 14 01:47:29 reporterpi grafana[405]: 2018/01/14 01:47:29 [I] Migrator: Starting DB migration
Jan 14 01:47:30 reporterpi grafana[405]: 2018/01/14 01:47:30 [I] Listen: http://0.0.0.0:3000
Jan 14 17:00:18 reporterpi grafana[405]: 2018/01/14 17:00:18 [I] Completed [::1] - “GET / HTTP/1.1” 302 Found 29 bytes in 16141us
