Accessing grafana behind nginx gives dashboard failures. Not sure why its failing. in the grafana.ini file I configured domain with localhost or the domain and it failures. When I access the site via port 3000 it works correctly.
NGINX config
location ~* /grafana/ {
proxy_set_header Host $http_host;
proxy_pass http://grafana;
# Proxy Grafana Live WebSocket connections.
location ~* /grafana/api/live/ {
rewrite ^/grafana/(.*) /$1 break;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
Grafana config
[server]
;protocol = http
;http_addr =
;http_port = 3000
domain = localhost
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
serve_from_sub_path = true
