Hello, I’m in the process of setting up Grafana after getting Prometheus up and running. Right now I’m running into an issue where if I go to example.com/grafana in my browser, I get this error as a json response:
{"message":"Invalid username or password"}
If I open the page in incognito mode, however, I get the standard login page and the login does work.
I noticed that if I turn auth.basic off in /etc/grafana/grafana.ini, the login screen does show up and I don’t get the error anymore. However, is this comprising security in any way since this is a public facing page?
I wonder this is related to the basic auth setup I did during the Prometheus installation. While setting up Prometheus, I created a new basic auth login with:
sudo htpasswd -c /etc/nginx/.htpasswd my_user
Could that somehow be interfering with Grafana’s login?
Here is what my Nginx config looks like:
# Grafana
location /grafana/ {
proxy_pass http://grafana.staged-by-discourse.com/;
# Prometheus
location /prometheus/ {
auth_basic "Prometheus server authentication";
auth_basic_user_file /etc/nginx/.htpasswd;
proxy_pass http://localhost:9090/;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
location / {
root /srv/www/home/;
Any help will be appreciated! I am really scratching my head here.
