Ive had this issue before, but forgot how i fixed it. I recently did a migration, got the same issue. I cannot fix it by building dashboard manually. Error still replicates.
Basically im adding overrides, bar chart. I have two series: When one is a bar, and one is a line, the width change is no issue.
NOW the problem, when i change both to bar, it groups(assuming), and the bar visual becomes very thin, and the line width slider no longer works.
Ive tried quite a bit for past hour. Used old panel to exact replicate, didnt work. tried groups, split the queries into two, tried as one etc etc. Cannot find the solution.
This is what i want, ive done it before:
Please help, thank you
