I have a mariadb view that deliveres the following data when you do:
select stunde, anzahl from wp_active_hours order by 1;
| stunde | anzahl |
| 0 | 452 |
| 1 | 363 |
| 2 | 374 |
| 3 | 342 |
| 4 | 408 |
| 5 | 386 |
| 6 | 634 |
| 7 | 1071 |
| 8 | 1672 |
| 9 | 2252 |
| 10 | 3247 |
| 11 | 3488 |
| 12 | 3932 |
| 13 | 3560 |
| 14 | 3256 |
| 15 | 3226 |
| 16 | 3161 |
| 17 | 2799 |
| 18 | 2594 |
| 19 | 1990 |
| 20 | 1389 |
| 21 | 364 |
| 22 | 5057 |
| 23 | 571 |
“stunde” means “hour” and “anzahl” means “counter”.
So the content of the table is a counter for each day+nighttime-hour from 0-23 o’clock.
I would like to create a Bar chart that has the hours 0 to 23 on the x-axis and
the counter value on the y-axis.
I tried a lot but but failed so far.
Can somebody help me with this?
I have Grafana 8.3.5 with a mariadb that holds the data.
Thank you. Regards Andi
