Hello everyone,
I’ve encountered an issue with the Loki ruler and my Mimir Alertmanager setup. Despite configuring the Loki ruler to forward alerts to the Mimir Alertmanager, it seems that the integration isn’t functioning correctly. I’m receiving error messages in both the Loki backend log and the Mimir backend. The errors read as follows:
Domain is altered for data privacy, service.io is just a placeholder!
In Loki backend log:
level=error ts=2024-04-04T09:48:16.641353044Z caller=notifier.go:532 user=anonymous alertmanager=https://mimir-backend.service.io/alertmanager/api/v2/alerts count=1 msg="Error sending alert" err="bad response status 422 Unprocessable Entity"
In Mimir backend log:
ts=2024-04-04T09:48:53.401865562Z caller=notifier.go:530 level=error user=anonymous alertmanager=http://10.41.0.228:20330/alertmanager/api/v2/alerts count=1 msg="Error sending alert" err="Post \"http://10.41.0.228:20330/alertmanager/api/v2/alerts\": EOF"
Here’s some context: Both Loki and Mimir are running as services on my Nomad cluster, with Loki in SSD mode and Mimir in read-write mode. Additionally, these services are exposed via a Traefik proxy. I attempted to enable multi-tenancy on both Mimir and Loki, but this adjustment didn’t alter the error message.
Below are my configurations
Mimir config:
ruler:
rule_path: /alloc/data/ruler
alertmanager_url: https://mimir-backend.service.io/alertmanager
ring:
instance_addr: 10.41.0.228
ruler_storage:
backend: local
local:
directory: /local/ruler
alertmanager:
data_dir: /alloc/data/alertmanager
external_url: https://mimir-backend.service.io/alertmanager
sharding_ring:
zone_awareness_enabled: true
instance_availability_zone: eu-de-01
Mimir test rule is saved in /local/ruler/anonymous:
groups:
- name: dead man switch
rules:
- alert: dead man switch
expr: vector(1)
labels:
severity: none
Loki ruler config:
ruler:
external_url: grafana.service.io
datasource_uid: loki
enable_alertmanager_v2: true
enable_sharding: true
wal:
dir: /alloc/data/ruler-wal
storage:
type: local
local:
Loki test rule is saved in /local/ruler/anonymous:
groups:
- name: dead man switch loki
rules:
- alert: dead man switch loki
expr: vector(1)
labels:
severity: none
Does anyone have insights into why this configuration is causing errors? Any help would be greatly appreciated.Thank you!
