Grafanamainbranch (also affects current releases). Running on Azure App Service (Linux, Docker). -
Using Azure AD OAuth withclient_authentication = managed_identity(User-Assigned Managed Identity) and refresh tokens enabled (use_refresh_token = true) for seamless session continuity. -
Configuration:
[auth.azuread]
enabled = true
managed_identity_client_id =
federated_credential_audience = api://AzureADTokenExchange
use_pkce = true
scopes = openid profile email offline_access -
What happened?
The initial login works perfectly. However, when the access token expires (~60 minutes), the token refresh fails silently and all users get logged out. This is becauseTokenSource()inazuread_oauth.gofalls through to the defaultoauth2.Config.TokenSource(), which doesn’t include aclient_assertion— unlike workload identity, which already has a dedicatedazureADTokenSourcehandling this correctly. -
Token refresh should work transparently, just like it does forclient_authentication = workload_identity. The session should continue without interruption. -
Yes, on every token refresh attempt:
logger=oauthtoken level=error msg=“Failed to retrieve oauth access token”
provider=oauth_azuread
error=“oauth2: “invalid_client” “AADSTS7000218: The request body must contain the following parameter:
‘client_assertion’ or ‘client_secret’.”” -
* Grafana docs for Azure AD OAuth configuration with managed identity.Additional context
I’ve filed an issue and submitted a fix with production-verified before/after results:
The fix adds a dedicated
azureADManagedIdentityTokenSourcefollowing the same pattern as the existing workload identity token source. After deploying the fix: zero AADSTS7000218 errors, sessions refresh without interruption.Looking for maintainer review on the PR — it’s been open since Feb 26 with no reviews yet. Thanks!
Github Issue and PR is closed with a Merge ![]()
