AWS Billing / Tags
Hello everyone,
I am currently trying to create billing dashboard filtered by tags (which correspond to a project) to be able to see expenses by project. As we can see in AWS Billing Cost explorer. Is it possible?
So far I can only make dashboard with global billing…
Thanks in advance!
Interested in that too. If any help come it will be appreciated.
I only need some guidance and I will create it :smiley:
So far, I had no success on that topic… :frowning:
But do you have build anything?
I would like this as well.
Parse AWS Detailed Billing Report (DBR) and the AWS Cost and Usage Report (CUR) into suitable DB (Elasticsearch) and then build dasboard.
Almost a year and half later, is there an easier way to get those Tags?
