Grafana 11.1.2 on Ubuntu 22_04 -
Creating a time series graph with counter data from Elasticsearch that gives the same outcome as when it is created in Elasticsearch itself (Kibana) -
What happened?
The data shown in the Time Series panel with Metric average gives a totally other graph than the one in Kibana. (The one in Kibana is correct).
It looks like the average calculation is completely different in Grafana and gives a completely misleading graph.
This is how the graph shoud look like:
This is how it looks with data from Elasticsearch:
Getting the same graph as in Kibana. -
This is the query in Grafana:
“datasource”: {
“type”: “elasticsearch”,
“uid”: “uidofdatasource”
“alias”: “”,
“bucketAggs”: [
“field”: “@timestamp”,
“id”: “2”,
“settings”: {
“interval”: “1m”,
“timeZone”: “Europe/Brussels”
“type”: “date_histogram”
“hide”: false,
“metrics”: [
“field”: “CTR.per hour”,
“id”: “1”,
“type”: “avg”
“query”: “host.hostname:$Smartbox”,
“refId”: “A”,
“timeField”: “@timestamp”
“title”: “$Smartbox Counter-data from Elastic (average on interval per minute)”,
“type”: “timeseries” -
No -
Could not find anything in the current info on the internet
I found the problem. There were 2 problems, one obvious one I did not see immediately and the second one was syntax. In Grafana the Lucene query was: host.hostname.keyword : $Smartbox.our.domain.name. With $Smartbox as variable.
The obvious problem: The name in $Smartbox was in Upper case and had to be in Lower case.
The syntax problem: The Lucene query needs to be written as following:
host.hostname.keyword : ${Smartbox:text}.our.domain.name
Problem Solved!
