Automation of publishing real time data to public
  1. Is there a process or method to automate publishing to non-Grafana users (e.g., the share to raintank.io)?
  2. Is there a process to update the data set? I can update my data set if I go to my designer and re-select the time range twice (e.g., go from last 12 hours to some other time range, then back to last 12 hours). Especially in light of #1, would like the shared ‘screenshot’ to include regularly updated data as well.
Thanks,
welcome to the :grafana: forum, @anon22310119
I think you might want to check out the new Public Dashboards feature that was added in Grafana v9.1. It might solve a lot of these headaches:
