Hello, i succesfully building Grafana from sources and it running using “./bin/grafana-server”, my question is how to make this Grafana auto start when booting and how to make it as services, so i can start it just by using “sudo service grafana-server start” or via systemd.
I’m still newbie using Linux, so need some help here, thanks.
SourceURL:http://docs.grafana.org/installation/debian/
or if you need it for centos/redhar Linux: http://docs.grafana.org/installation/rpm/
Start Grafana by running:
This will start the grafana-server process as the grafana user, which was created during the package installation. The default HTTP port is 3000 and default user and group is admin .
Default login and password admin / admin
To configure the Grafana server to start at boot time:
sudo update-rc.d grafana-server defaults
Start the server (via systemd)¶
To start the service using systemd:
systemctl daemon-reload
systemctl start grafana-server
systemctl status grafana-server
Enable the systemd service so that Grafana starts at boot.
sudo systemctl enable grafana-server.service
