Auto refresh per panel
Hi all.
I have this dashboard which contains a single-stat panel and is auto refreshed every 0.5 seconds. Data source is elasticsearch and there are no performance issues here. Now I would like to add a graph-panel with a month of data - I do not wish to auto-refresh this every 0.5 seconds. Any way of overriding the auto-refresh per panel?
Hi @scaarup,
The refresh rate is a property of the dashboard, not the panel. It’s not possible to have a different refresh rate for specific panels within a dashboard.
Hi.
Thanks for your reply.
Is this a candidate for a feature request?
You may want to follow the discussion here: https://github.com/grafana/grafana/issues/3514
I am also interested in such a feature. Are there any updates yet?
Another year and a half, also interested. Most of my dashboard panels update every 30 seconds, but one of those charts is a daily aggregate. It only needs to update… anywhere from hourly to 24 hours, but definitely not 30 seconds.
I am also interested.
Instead of a refresh rate for each panel, maybe it is better to have 2 different profiles (1 more than currently, and optional) (easier to manage for users / to create in Grafana).
a “Standard rate” (the refresh rate currently in place), where you define a refresh time for the panel that will refresh ‘by default’ (for example every 30s)
a “Secondary rate” (optional), for panels that will refresh more or less often than the standard (10m for example if you want a slower rate, or for example 15s if you want faster)
Then you specify in the panels concerned those that should not use the standard rate.
