Authentication with API key randomly fails in Linux script
    9.01 on Oracle Linux 7.9
    Export dashboard json files from a scheduled job running under cron
    I copied this script and generated an API key with ‘viewer’.
    I can run it on one system . I copy this script to another system (same Grafana, OS, API key) and run it I get an error because it thinks the key is ‘0000000’.
    Sometimes this happens on the first system as well.
    I thought I might use a service account. I have created one, but don’t know how to use it in the ‘curl’
HOST=‘http://grafana.staged-by-discourse.com’
DASH_DIR=/usr/local/SAdata
KEY=“*********”
ORG=AAM
for dashboard_uid in $(curl -sS -H "Authorization: Bearer $KEY" $HOST/api/search\?query\=\& | jq -r '.[] | select( .type | contains("dash-db")) | .uid'); do
    url=`echo $HOST/api/dashboards/uid/$dashboard_uid | tr -d '\r'`
    dashboard_json=$(curl -sS -H "Authorization: Bearer $KEY" $url)
    dashboard_title=$(echo $dashboard_json | jq -r '.dashboard | .title' | sed -r 's/[ \/]+/_/g' )
    dashboard_version=$(echo $dashboard_json | jq -r '.dashboard | .version')
    folder_title="$(echo $dashboard_json | jq -r '.meta | .folderTitle')"
    # You can export the files like this to keep them organized by organization:
    mkdir -p "$DASH_DIR/$ORG/$folder_title/dashboards_$ORG"
    echo $dashboard_json | jq -r {meta:.meta}+.dashboard  > $DASH_DIR/$ORG/$folder_title/dashboards_$ORG/${dashboard_title}_v${dashboard_version}.json
done
  • What happened?
    I get an error from the ‘jq’, but that is because the first ‘curl’ does not return any data.
    exports the dashboard json files to /usr/local/SAdata…
    KEY and HOST are fine. I don’t include them for security reasons
    aamlxgmp001 mckenns /home/mckenns $ curl -sS -H “Authorization: Bearer $KEY” $HOST/api/search?query=&
    {“message”:“invalid API key”,“traceID”:“00000000000000000000000000000000”}
    Local deployment using the OSS version of Granfana 9.01
