What Grafana version and what operating system are you using? alloy, version v1.9.2 using Rocky 9.5
What are you trying to achieve? Setting up authentication ( any kind ) between Alloy agent and Alloy proxy
How are you trying to achieve it? using prometheus.receive_http
What happened? i cant seem to setup any kind of authentication between then so only authenticated servers can send data
What did you expect to happen? tried http {} block but its not working
Can you copy/paste the configuration(s) that you are having problems with? Yes here it is: http {
auth {
basic {
username = “admin”
password = “/etc/alloy/secrets/mimir-password”
filter {
paths = [“/metrics”, “/v1”]
authenticate_matching_paths = true
}prometheus.receive_http “receiver” {
http {
listen_address = “0.0.0.0”
listen_port = 9201
auth {}
forward_to = [prometheus.remote_write.mimir.receiver]
}prometheus.remote_write “mimir” {
endpoint {
url = “http://mimir:8082/api/v1/push”
basic_auth {
username = “admin”
password_file = “/etc/alloy/secrets/mimir-password”
headers = {
“X-Scope-OrgID” = “default”,
external_labels = {
datacenter = “CAL”,
}prometheus.exporter.unix “default” {
include_exporter_metrics = true
disable_collectors = [“mdadm”]
}prometheus.scrape “default” {
targets = prometheus.exporter.unix.default.targetsforward_to = [
prometheus.remote_write.mimir.receiver,
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. When i tried auth inside receiver_http it doesnt exist
Did you follow any online instructions? If so, what is the URL? Did not find any accurate ones
Looking at the HTTP block I don’t see a way to configure simple auth.
Not sure how you segment your network, but I don’t think this is a common use case. If you really want authentication on an Alloy proxy, putting alloy behind nginx with simple auth might be your easiest workaround.
