Hi all,
Unfortunately I’m not able to build the Docker image for armv7 with the current grafana release version. I am working on Windows 10.
The build always stuck at dockerfile step:
“COPY --from=go-builder /grafana/bin/ /grafana-server /grafana/bin/ /grafana-cli ./bin/”
Please can you give me a hint. Thanks in advance.
welcome to the
forum, @peterlets
just curious, are you modifying something that requires you to build your own, unique docker image? Will this armv7 image not work for you?
https://hub.docker.com/layers/grafana/grafana/8.4.3-armv7/images/sha256-7e2e22d0b59157aa1483ce401ededaa60d7e122484cc410934587f8da9bc5eea?context=explore
Hi matt,
thanks for your reply. Yes, I’m trying to modify different stuff in the source code. I gave a try and I am able to build arm64 images but with armv7 and buildx function, it stucks like described at the last stages.
I changed the Makefile and use the command make build-docker-full.
The command inside the Makefile for docker build is:
docker buildx build - -tag grafana/grafana:dev - -platform linux/arm/v7 –load .
I’m using the newest docker desktop version. I also update yarn, Nodejs and go but now changes to the described issue.
Hi matt,
please can you give me an answer to that topic.
Thank you in advance.
