Application error logs using loki
Architecture
• Promtail → Agent which read the log for log file.
• Loki → server
• Grafana → Data visualization tool to disply logs for different different visualization panels like time-series, bar chart , stat visualization.
• Using loki query fetch data from server and disply on Grafana widgets
Step 1 : Folder structure
Make these folder and file.
Step 2 : Downlode loki. Exe and promtail.exe file form github.
Now open notepad and configure loki and promtail configuration file
loki configuration file
Run command to start loki and then promtail
loki-windows-amd64.exe -config.file=loki-config.yaml
promtail-windows-amd64.exe -config.file=promtail-config.yaml
Step 3:
Now import the application-error-logs Json in grafana
Step 4:
Loki query to fetch logs by loki server and display on grafana panels
Note : Logs display according to time
Application Errors
Application Warnings:
Total error count
