App scan security issues
Hi Team,
We are using grafana v9.1.1 and it is deployed in Kubernetes env. Recently did Appscan security testing and found below 3 high severity and 1 medium severity issue. Can you suggest any patch available where these issues are already fixed ? If not any plan to fix these issues near future.
High:
API Broken Function Level Authorization
API Mass Assignment
SQL Injection
Medium:
Cross-Site Request Forgery
Team,
Any suggestions ?
Regards,
Ajay
@grafana team it is April 2023,updated to Grafana-9.4.7 and HCL AppScan vulnerability scan still displays following “vulnerability”
Risk(s): API Mass Assignment exploitation may leads to privilege escalation, data tampering, bypass of security mechanisms
Fix: Avoid using functions that automatically bind client’s input to code variables or internal objects.If applicable, explicitly define
and enforce schema’s for the input data payloads.
Variant 1 of 1
The following changes were applied to the original request:
Set body to
'{“queries”:[{“datasource”:{“type”:“prometheus”,“uid”:“abcdefghijk”},“expr”:"count(up{job="www_hea
rtbeat"})“,“instant”:true,“interval”:”",“legendFormat”:“TOTAL”,“refId”:“G”,“exemplar”:false,"requ
estId":“12G”,“utcOffsetSec”:-14400,“datasourceId”:1,“intervalMs”:15000,“maxDataPoints”:391},{"data
source":{“type”:“prometheus”,“uid”:“abcdefghijk”},“expr”:"sum(probe_success{job="www_heartbeat"})
“,“instant”:true,“interval”:”",“legendFormat”:“up”,“refId”:“B”,“exemplar”:false,“requestId”:“12B”,
“utcOffsetSec”:-14400,“datasourceId”:1,“intervalMs”:15000,“maxDataPoints”:391},{“datasource”:{"typ
e":“prometheus”,“uid”:“abcdefghijk”},“expr”:"count(up{job="www_heartbeat"})-sum(probe_success{job
="www_heartbeat"})“,“instant”:true,“interval”:”",“legendFormat”:“DOWN”,“refId”:“A”,“exemplar”:f
alse,“requestId”:“12A”,“utcOffsetSec”:-14400,“datasourceId”:1,“intervalMs”:15000,“maxDataPoints”:3
91}],“range”:{“from”:“2023-04-06T15:53:18.673Z”,“to”:“2023-04-06T15:58:18.673Z”,“raw”:{“from”:"now
-5m",“to”:“now”}},“from”:“1680796398673”,“to”
Reasoning:
The test result seems to indicate a vulnerability because the Test Response is successful (returns
200 OK), indicating that the Application/API access is successful.
Request/Response:
POST /grafana/api/ds/query HTTP/1.1
Host: example.org
Connection: keep-alive
x-plugin-id: prometheus
x-grafana-org-id: 1
x-panel-id: 12
User-Agent: Mozilla/4.0 (compatible; MSIE 9.0; Win32)
content-type: application/json
accept: application/json, text/plain, /
x-dashboard-uid: xyz
x-datasource-uid: abcdefghijk
Accept-Language: en-US
Sec-Fetch-Site: same-origin
Sec-Fetch-Mode: cors
Sec-Fetch-Dest: empty
Referer: https://example.org/grafana/d/xyz/team-home-dashboard?orgId=1
{“queries”:[{“datasource”:{“type”:“prometheus”,“uid”:“abcdefghijk”},“expr”:"count(up{job="www_hear
tbeat"})“,“instant”:true,“interval”:”",“legendFormat”:“TOTAL”,“refId”:“G”,“exemplar”:false,"reque
stId":“12G”,“utcOffsetSec”:-14400,“datasourceId”:1,“intervalMs”:15000,“maxDataPoints”:391},{"datas
ource":{“type”:“prometheus”,“uid”:“abcdefghijk”},“expr”:“sum(probe_success{job="www_heartbeat"})”
,“instant”:true,“interval”:“”,“legendFormat”:“up”,“refId”:“B”,“exemplar”:false,“requestId”:“12B”,"
utcOffsetSec":-14400,“datasourceId”:1,“intervalMs”:15000,“maxDataPoints”:391},{“datasource”:{"type
":“prometheus”,“uid”:“abcdefghijk”},“expr”:"count(up{job="www_heartbeat"})-sum(probe_success{job=
"www_heartbeat"})“,“instant”:true,“interval”:”",“legendFormat”:“DOWN”,“refId”:“A”,“exemplar”:fa
lse,“requestId”:“12A”,“utcOffsetSec”:-14400,“datasourceId”:1,“intervalMs”:15000,“maxDataPoints”:39
1}],“range”:{“from”:“2023-04-06T15:53:18.673Z”,“to”:“2023-04-06T15:58:18.673Z”,“raw”:{“from”:"now-
5m",“to”:“now”}},“from”:“1680796398673”,“to”:“1680796698673”,“is_admin”:true,“is_sso”:true,“role”:
“admin”}
HTTP/1.1 200 OK
Date: Thu, 06 Apr 2023 16:07:03 GMT
Server: Apache
Strict-Transport-Security: max-age=63072000
Cache-Control: no-store
Content-Security-Policy: script-src ‘self’ ‘unsafe-eval’ ‘unsafe-inline’ ‘strict-dynamic’ 'nonce-
BJxd2DTka/W5jHH/Ynx9lw’;object-src ‘none’;font-src ‘self’;style-src ‘self’ ‘unsafe-inline’
© Copyright HCL Technologies Limited 2000, 2023. All Rights Reserved. - 8 -
blob:;img-src * data:;base-uri ‘self’;connect-src ‘self’ example.org
ws://example.org/grafana/ wss://example.org/grafana/;manifestsrc
‘self’;media-src ‘none’;form-action ‘self’;
Content-Type: application/json
X-Content-Type-Options: nosniff
X-Frame-Options: deny
X-Xss-Protection: 1; mode=block
Content-Length: 1472
Keep-Alive: timeout=15, max=43
