I’m developing an app plugin which has a panel and uses the datasource proxy to forward requests through the grafana instance.
I have signed this privately so that I can manually deploy it on my private instances of grafana.
When running in the the scaffolded compose file it works fine and I am able to proxy through the route and update configurations:
but when I then install this on another instance of grafana, also through docker compose, on the same address (so the private signature still works). The proxy doesn’t go anywhere and I can’t update the configs:
I also get these errors on the log:
grafana-1 | logger=context userId=1 orgId=1 uname=admin t=2024-11-26T10:45:10.534877761Z level=info msg="Request Completed" method=GET path=/api/gnet/plugins/test-app status=404 remote_addr=172.20.0.1 time_ms=43 duration=43.753392ms size=116 referer=http://localhost:3000/plugins/test-app handler=/api/gnet/* status_source=server
I can see the plugin be registered in the log and the frontend works but it appears to not launch the proxy. Is there a setup step that I’ve missed which the scaffolded compose does for me?
