API compatibility between different versions
Hello! Does anybody know if there were any breaking API changes between Grafana version 6.X and 7.X ? Specifically in the Alerting API and Dashboard API.
And is there any way to check the compatibility of the different versions? Maybe there is a document somewhere that describes the breaking API changes?
