hi, is there an api call i can use to get the iframe code that allows me to share my panel inside an iframe? for example when i click share -> ebmed on a specific panel, i see the html iframe code that i can copy and paste into a different website to display the grafana data.
is there an api call that can pull the iframe info for all of my panels?
I meaning that is not possible or not viable. The json only contain the struct of the dashboard/panel not the data
But the true is that is posible, you only need copy and paste the json model and call the API with it
admin:YOURPASSWORD@community.grafana.com/api/snapshots
"dashboard": PASTE_HERE
i’m trying to create a webpage that will auto embed all the iframes from my grafana server. would the snapshot api call help me do this?
I think that is not possible, but u can try use scripted dashboard
