I did not get it working.
Until now I use ldap against MS AD (by the way: it would be nice if it would be impossible for the users to edit the username).
I tried everything to get SSO working - without success.
Please help me!
Cant get to your link, is this where you described about how to access Kerberized cluster using Grafana or something similar. Please provide the link again
You’re welcome venkata. I just made that scenario for my fun. I didn’t go production. Grafana don’t support Kerberos authentication. So I decided to do a little trick. I installed an Apache2 which support Kerberos authentication well. I set up a FreeIPA authentication and authorization server too. I set up the Apache2 to run as a reverse proxy for Grafana with Kerberos auth. So, on my terminal I can run kinit user@domain, enter my password and I transparently log in Grafana without type my user and password again on Grafanas login page. I hope I was clear. If not please let me know.
Okay thank makes sense laszlolaszlo :). Thanks for detailing.
in fact, what i am looking in is, I have a Druid data source behind a kerberized env. I am trying to access the data source from grafana and Grafana does not allow me to use a Kerberized login to the datasource.
like you said, if Grafana does not support kerberization, then I cant make my thing happen right? Please provide any insights, alternatives etc.
I see venkata what you like to do. So if I’m right you want to connect with/from Grafana to a datasource which need Kerberos authentication. I found some links:
We have almost the same problem as ventaka but with a different data source. We use OSIsoft PI data sources. In order to implement data level security, we need to use Kerberos authentication which does not appear to be currently supported in Grafana.
Are you able to provide me with any alternatives or insights, as our eventual aim is to implement a SSO solution in which users are defined and authenticated in Active Directory and are not required to log into Grafana.
