Hello All,
I am able to calculate an individual request response time as shown below.
const res = http.get(`http://localhost:9000/page/1`);
page1.add(res.timings.duration);
Along similar lines is there any possibility to find the response time of all the requests in a group as shown below?
group('group_page23', function () {
http.get(`http://localhost:9000/page/2`);
http.get(`http://localhost:9000/page/3`);
Regards,
Bharath.
Tom_1
2
If you want group statistics to appear in the end-of-test summary, you will need to add a threshold for it until we implement #1321.
For example:
import { group } from 'k6';
import http from 'k6/http';
export const options = {
thresholds: {
'group_duration{group:::My Group}': ['max>=0'], // will always pass
'group_duration{group:::My 2nd Group}':['p(95)<=200'], // an actual threshold
export default function () {
group("My Group", function() {
http.get('https://httpbin.test.k6.io/anything');
http.get('https://httpbin.test.k6.io/');
group("My 2nd Group", function () {
Will produce output that looks like this:
data_received..................: 265 kB 392 kB/s
data_sent......................: 7.9 kB 12 kB/s
group_duration.................: avg=328.94ms min=193.83ms med=334.15ms max=466.51ms p(90)=458.53ms p(95)=466.51ms
✗ { group:::My 2nd Group }.....: avg=210.57ms min=193.83ms med=206.72ms max=235.17ms p(90)=224.08ms p(95)=229.62ms
✓ { group:::My Group }.........: avg=447.3ms min=433.12ms med=442.12ms max=466.51ms p(90)=466.51ms p(95)=466.51ms
http_req_blocked...............: avg=66.2ms min=0s med=0s max=265.88ms p(90)=264.83ms p(95)=264.85ms
http_req_connecting............: avg=19.34ms min=0s med=0s max=80.62ms p(90)=76.23ms p(95)=80.62ms
http_req_duration..............: avg=98.15ms min=78.86ms med=95.04ms max=127.8ms p(90)=118.88ms p(95)=122.9ms
{ expected_response:true }...: avg=98.15ms min=78.86ms med=95.04ms max=127.8ms p(90)=118.88ms p(95)=122.9ms
http_req_failed................: 0.00% ✓ 0 ✗ 40
http_req_receiving.............: avg=2.02ms min=0s med=0s max=18.45ms p(90)=7.13ms p(95)=9.19ms
http_req_sending...............: avg=3.88µs min=0s med=0s max=84.2µs p(90)=0s p(95)=12.46µs
http_req_tls_handshaking.......: avg=24.96ms min=0s med=0s max=103.2ms p(90)=100.92ms p(95)=101.4ms
http_req_waiting...............: avg=96.12ms min=70.97ms med=94.22ms max=127.8ms p(90)=118.8ms p(95)=122.9ms
http_reqs......................: 40 59.231986/s
iteration_duration.............: avg=657.88ms min=638.92ms med=658.13ms max=673.3ms p(90)=668.8ms p(95)=671.05ms
iterations.....................: 10 14.807997/
