i use annototations. I have a template where I use $host as my variable.
when i enable annototations the annootation comes to all the charts. Is it possible to isolate the annototation to the particular host?
Not supported. If you find this feature really helpful I would suggest you to create a feature request issue. Please search open/closed issues before creating a new one in case someone already requested this.
If enough people upvotes the issue with a thumbs up emoji we’ll consider implementing/merging it.
Marcus
