Grafana Annotation - Prometheus
I have a prometheus annotation that it is working fine. However, I have the following question:
Can an annotation be fed by a template variable?
For instance:
ALERTS{alertname=“Service_Down”, alertstate=“firing”,instance="$host"}
Where $host is from a template:
label_values(jvm_memory_bytes_used{role=“prod”}, instance)
Thanks,
Lp
Yes, it does. Your syntax looks correct too. Are you getting any errors?
Ciao Danielle,
It works.
Thanks.
Lp
