v9.5.1 docker image on CentOS -
Am trying to add the current time as an annotation line on a time series chart spanning now-12h to now+12h. -
Similar to this post, but am using a Prometheus data source for this panel (the back end is actually VictoriaMetrics).
I have been attempting to make a comparable annotation for the Prometheus data source, but have not been able to find a syntax that gives me a single annotation line. -
What happened?
For instance, I though thattlast_change_over_time(mqtt_value[1m])would return a timestamp for the most recently updatedmqqt_valuemetric, but what I get is an annotation line every 15mins up to the current time.
Thanks in advance for any pointers!
