does anyone know a plugin or a function how to make a animated line, changing the color (or similar) according to a database value?
I mean I want to draw a dotted line from a charger to a battery and make it green/red, depending on if its loading or draining the battery.
TIA!
Yeah, that’s nice but I´m not looking for animated charts, I´m looking for animated lines…
can you show us what you want via some sort of drawing and the data behind it
Something like this (the line, depending on the value)
I would prefer dotted lines, maybe even moving from one device to another, depending on if its a positive or negative value
hi
try plugin FlowCharting
i use it for animated dashboard
best regards
Yeah, thats what I looked for! Thanks!
